Headlight switch 3XW OZ
Started by FJSpringy, September 08, 2012, 07:21:04 PM
FJSpringy
Fitted an on/off switch awhile back, just a toggle switch in the neutral line so I can control both high and low beam, one thing that pleasantly  surprised me was when you turn the headlight of using this method the high beam light on the dash comes on telling you the lights are off.
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
Horse
Hi springy, was thinking of doin just that myself, but what And where is this neutral line u mention   :sorry: I haven't looked up the mod yet ,any pics of watt u done???   :drinks:   Horse.... ......
There is no great genius without some touch of madness
And Never Underestimate the Predictability of Stupidity !!
Quote from: Horse on September 12, 2012, 01:15:54 AM
3 wires go to the headlight globe, 1 positive to low beam filament, 1 positive to high beam filament and 1 shared earth wire......I believe this is the wire you fit a switch to.
FJSpringy
I got these off ebay
http://www.ebay.com.au/itm/H4-HB2-Head-light-Bulbs-Wire-Plug-Heat-Resist-Truck-Van-/370451328777?pt=AU_Car_Parts_Accessories&hash=item56409eaf09
cut the earth put in a switch. That way I didn't have to cut the harness and could take it out if I didn't like it.
The Haynes manual has wiring diagrams, thats what I used, can't remember which colour the earth was.
BUT if you buy the EXACTLY the same as above, I cut into the black wire.
I have kleptomania,
92 FJ1200
Horse
Thanx guys, gunna do it this week end :drinks: :drinks: :drinks: :biggrin:
FJSpringy
Cool, Your bike will like you when your starting it, much happier.
BTW remember the only wire I cut was on the extender I got off ebay.
Dave
I have kleptomania,
92 FJ1200
flips
OR...
If you have a severe case of moditis you could get an early fj  rhs switch block with a headlight switch on it and rewire the harness  :wacko3:
Cheers  :drinks:
Jeff P
Stay rubber side down.
FJSpringy
I looked at this but would have lost the hazard light switch :(
I have kleptomania,
92 FJ1200
Horse
Yes, but really the hazzards only work with the key on  :dash1: who wants to sit on the side of the road fixing a prob wlth the key turned on????:drinks: :drinks:
FJSpringy
 but if you had a headlight switch  :lol: :lol: :lol: :lol:
I have kleptomania,
92 FJ1200
flips
Maybe a separate non ignition switch for the hazards and an early fj switchblock for the lights?? :unknown:  :wacko2:  :rofl:
Horse
All done, works a treat  :good: really hate boring 12 mm holes in the fairing side panels for the switch but  :ireful: ,it has a crack in it any way, will replace one day!!!!  And yes, the tell tail ie the high beam light is on when the lights are off  :biggrin:  I can live with it   :drinks: :drinks:
FJSpringy
I have kleptomania,
92 FJ1200
radiotek
I thought about using the Pass button to do the Hi/Lo switch using a latching relay. That way I could use the original hi/lo switch as the headlamp on/off switch. I have never used the pass button and often thought it would make a better 'push to talk' button for the radio.
On the bro in laws fj we also did a switch job but rewired the light circuit in 4.0mm wire and used a relay. This made a big difference to the brilliance of the light with maximum voltage available at the globe. Using a relay allows a broader choice of switch as the current is minimal
1988 XJR1300
