oil leak
Started by Mark, September 18, 2012, 03:39:46 AM
Mark
[img]http://fjowners.com/gallery/3/medium_2724_18_09_12_2_25_57.jpeg[img]
fired up the project fj today and irs got 2 oil leaks frombetween crankcases adjacent to front engine mounts,i had a lot of pressure in this area freeing up the mount pins.anyone seen this before i assume motor out and split cases to sort it out,also can anyone tell me where this bracket belong, many thanks
All I ask of living is to have no chains on me( Laura Nyro)
Mark
Oil cooler line mounting bracket
Mark
Thanks for the info on bracket Randy,did you see my post about oil leaking from between crankcases on both sides near front engine mounts, any ideas what I can do here, would splitting the cases and using some type of sealant on surfaces work,prob should have split it and replaced bearings to start with anyway.thanks again
