Stock carb settings?
Started by wakdady, June 14, 2012, 08:46:10 PM
wakdady
Well, sadly I cannot afford a new exhaust at the moment. I have to install the original exhaust if I want to ride. I had it running jets with Randy's suggestions.
The question is, with a drop in uni filter and stock exhaust, what settings should i be running? Jet sizes, clip location and mixture screw.
I know, noob question,but what can I say, lol.
Thanks guys!
:music:
Very close to stock IMO.
You might want to open up the mix screw 1/4 - 1/2 turn IF YOU NEED IT (backfire on overrun).
May also want to lift your carb needles by 0.5mm (20 thou - 1/2 groove) by adding the washer.
But these are probably unnecessary.  Stock should run fine.
Kinda toasty down under in the summer months so for cooler running, I would suggest #40 pilot jets instead of the stock 38.5's.
weymouth399
 :sorry: stock is 37.5
Bob Snarky W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
wakdady
middle slot, depending on model
Henry, it helps when you can remind us on what model you have...Looking back to your early posts, you have a '90 model, if so... and assuming you have a UK model, common in Australia, you already have #42.5 pilot jets and your stock needle clip setting is 2nd from the top.
Ok, wait a minute Henry....it's you!! The Aussie map threw me.....? Is that even a Aussie map?  You still have your FJ?  Good for you.
It's not too warm in the bay area, go with your stock set up, 37.5 pilots they should be fine.....40's are ok also.
Randy says that with the adjustable needles the 3rd clip down from the top matches what the oem non-adjustable (USA) needles setting.
Air/idle screws start at 3 turns out, then adjust as the blip test warrants.
It was good to see you in Porterville... :good2:
Mike Ramos
Good morning,
I also use the stock exhaust on my 1991 with the Uni air filters. I would suggest following Randy's advice re: carb settings. I did and (cool in the Bay Area? Try the Walnut Creak/Concord temperatures) and you will find all around good performance, without back fires, pinging etc. regardless of the temperature, road conditions or time of day...
The Uni filters also have a pleasant intake sound as well. While I believe you will have an increase in power, I can't say for sure, but it feels like it.
Mike Ramos.
Quote from: Pat Conlon on June 15, 2012, 01:41:11 AM
I thought it was a map of the IOM course.  But it's too small to really tell.
wakdady
This is why we can't have nice things! It's the Nuerburgring!
:music:
wakdady
How hard would it be to weld a universal canister onto the remnants of the v@h 4-1 header and midpipe? I might try that.
Henry, check your PM's
Flynt
Quote from: wakdady on June 14, 2012, 08:46:10 PM
a new exhaust...
Henry - It's Frank in San Jose.  I have the exhaust that was on Klavdy's FJ when I bought it...  Header is not great, but definitely useable and the muffler is pretty nice.  It is super trap, but not the one with the plates.  You come get it and it's yours.
Let me know if you're interested.
