Hesitating throttle and popping noise
Started by WhiteBeard, March 31, 2013, 11:51:07 AM
poker007
Hi
  Just a thought.. When was the last time you had the valves adjusted ? I think its every 9k..Also what type of gas do you run? I always run the same  Chevron 91 octane :good2:...Good Luck,,
MarkG
1980 GT80( dirt) gone 1979 IT250  ( have)
1975 MX400(dirt) gone
1979 RD400 gone
1980 KZ1000st/ shattered right arm/ (ouch) gone thank GOD!
1995 FZR600 ( missed @gone)
1985 FJ1100 (TEL DEATH; DO WE PART)
You can, and should, adjust the mixture screws while she's running, don't have to pull the carbs for that...
WhiteBeard
Quote from: RichBaker on June 17, 2013, 10:17:35 PM
Thanks for the tip, Rich.
Are the mixture screws hidden underneath the golden plugs on the engine side?
Do I drill them out to access the screws?
Nat
They possibly are , but be carefull drilling out the brass plug, the mix screws are just below them,,,most places got the carbs with the rubber covers over the mix screws
