Opinions - what chain lube do you use and why
Started by terryk, April 01, 2012, 09:49:42 PM
Quote from: Arnie on April 18, 2012, 09:22:57 PM
Looking at the pic available on Clippard's site, you have a choice of 4/40 threaded connectors, or 1/16" barbs, or 1/8" barbs.
Thanks, I thought the 4/40 thread was the mounting points.
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Quote from: Dads_FJ on April 18, 2012, 10:14:08 PM
Um...I think they are still mounting points, from looking at the diagram. Just being the Geek/Engineering type looking at diagrams...  I hope you like barb fittings.... just saying....
Barb fittings would be fine, this would be a low pressure application.  However, it seems this valve is suppose to attach to a manifold or used with something else - I don't believe one can use this valve by itself.  Where are the barbed fittings, are they the items labled 'outlet' and 'inlet'?
'06 KTM 200XC
'43 BSA WM20
