Oil Capacity
Started by ButtButter, February 16, 2012, 10:46:25 AM
ButtButter
Can someone please tell me the exact amount of oil to in my '92 FJ1200? I don't have a manual and I want to be sure I don't add too much.
Thanks, :music:
1992 FJ1200 ABS
1983 VF750F
1982 CB900F
1975 BMW R75/6
gripit_N_ripit
Quote from: ButtButter on February 16, 2012, 10:46:25 AM
Thanks, :music:
When filling the fj with oil, put a couple quarts in, then hold the bike upright preferrably not on the center stand and add oil until its at the proper level in the sight glass located just below the oil fill cap.
Curtis
terryk
Quote from: gripit_N_ripit on February 16, 2012, 10:59:35 AM
Thanks, :music:
Why not on the centerstand ?
gripit_N_ripit
read it somewhere on the forum.. guess it doesnt really matter :pardon: of course you get the best reading when on level ground.
Curtis
Flying Scotsman
3.5 quarts should do it.You might need less if theres still oil in the filter or oil cooler.
1990 FJ1200
1999 GP1200 (165 + hp)
weymouth399
The capacity is stamped in the clutch cover, under the filler cap.  :dash2:
3000ml, just over 3 quarts, 946ml to a quart.
Bob W
It does make a small difference, if on the center stand vs on the ground.
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
I typically use 4 qts.  I fill it until the window is FULL up. Otherwise the Oil level light comes on under Kookaloo.
moparman70
I just did an engine swap where all the oil was removed.  To fill it took 4 quarts but I think for a regular oil change 3 would do as you don't really get all of it out.  The site glass as mentioned is the best way and like Ed says keep it close to the top to avoid the red glow.
stevecc
candieandy
i alway do 4qts of royal purple, but i have a spin on filter which holds .5 qts by itself.
HAUI
