sprocket problem!!!!!why
Started by cjv90, December 19, 2011, 12:56:09 AM
cjv90
Why in sam hell is it so hard to get the sprocktet bolts to break loose. I put all the army muscles i have and cant get them to budge. I just want to put a frsh coat of paint on it. Any ideas???? Thanks as usaul guys.
"Ive got an arm like a rocket,cock like a bermese python,and a mind like a scientist" - kenny powers
flips
Hi there.
I'm guessing the rear sprocket?.Do the nuts look "painted on"?.If so I would try heating them with a gas torch.If they look rusted on I would try a good spray of wd40 and let em soak for a bit then try again,maybe heat with the torch as well.Some moderate tapping with a hammer may help if rust is the problem. Have you got access to a rattle gun?...that should make short work of them.It seems strange that they are so hard to remove.I just changed my rear sprocket with just a normal socket driver :scratch_one-s_head: I'm sure others will chime in with better suggestions.Good luck :smile:
Jeff P
P.s just wonderin......which army? :biggrin:....just kidding! :flag_of_truce:...don't shoot  :flag_of_truce:
Stay rubber side down.
Is it OEM sprocket? I believe the factory used loctite on them.......maybe a bit of heat will do the trick........If I remember correctly, I had to use a shock driver with a 1/2 socket adapter to break mine loose the first time I changed sprockets.
Heat breaks the locktite loose.   90s with a propane torch will do the trick for each of them.
cjv90
Got them with some heat.... Thanks gentleman.
