i found my biggest oil leak
Started by srutherford, December 11, 2011, 11:44:23 AM
srutherford
i found the biggest oil leak. if you guys havnt heard first it was the filter housing,valve cover gasget/grommets,clutch push rod seal,main seal,and counter shaft seal. now the big on geanerator oil seal on the generator shaft. i said ahhhhh haaaa. but the bearing cap/seal in the genrator housing on the crank case seems fine wich is good because it appears to be discontinued. but the one that is ruptured is on its way along with the speedo cable i wish i had some pics to show but at the time i dont.
question
why does the oil pass through the generator/crankcase. there is a journal there!
just courious to cool mabe ??????
hope some one can understand my lack of correct words
thanx
silas
p.s  bike sat for along time only 13,000.on her
