Battery types for FJ?
Started by WhiteBeard, September 26, 2011, 07:56:47 AM
wow, those sort of temps  battery life even unused should improve the life of them ,as down here the cold takes its toll,even using a trickle charger, and about the hottest we see is about very low 30c and that dousnt happen often  in summer :dance2:
Quote from: fj11.5 on November 29, 2011, 07:17:30 AM
Yep, Tucson typically has lows of ~28F (overnight) in winter, to 110F highs in the summer. 90+F starts in May and goes til November... we saw a cold spell last year that hit 17F, hottest we've seen was 117F a few years ago. Phoenix sees 120+F in summer....
Quote from: RichBaker on November 29, 2011, 08:40:57 PM
I was in Phoenix during the last record breaking temp. I was working in the parking lot of a resort about 5 miles from the airport. The report on the security radio said that all departures have been suspended due to runway temps (in the shade) measuring at 122F. Commercial aircraft not being rated beyond 120F get grounded since the runway distance requirement is off the charts. FYI, it was just a hot day to me... But it is a DRY heat.... Very different than a 90/90 heat.
dont think ill be moving over that way anytime soon  :rofl2: too warm for this little black duck  :sarcastic:
Speaking of batteries, I will have AGM batteries on the shelf today. Once I get them in hand I will add them to my inventory.
I also added a battery maintenance charger for winter storage. Unlike most of the common brand of these chargers which just supply a constant mA charging voltage, this one modulates the charge rate. It safely maintains Wet, Gel, MF and AGM batteries, plus it will also work on 6 volts systems as well.
Paul Dodge
Check out battery mart.com . Good selection,free shipping. Paul
I've had my battery on a maintenance charge for over a week now, after it went flat over our winter recently. (yes, we have winter in Queensland  :smile:). If this battery doesn't hold charge, instead of spending around $160.00 on another Yuasa, I might get one of these AGM beauties, http://www.allpurposebatteries.com.au/product_info.php?products_id=48   and they have 250 cold crank amps compared to the Yuasa 200 CCA.
Hoo Roo
Tengu
Winter? in Queensland? I didnt notice it!  :blum1:
However I find Qld winter the best time to get out and ride... nice sunny days and the FJ doesnt run too hot either
Compared to our summers which are turning into monsoon seasons!
As for batteries - I have and use a smart charger called OptiMate and reckon it is brilliant. It has saved my battery and keeps it running better than ever. Its abotu the same price as a battery and has saved m replacing a few!
I got it from Steve at Moto Tech Diagnostics (local QLD fellow) good fellow as well!
http://mototechdiagnostics.com.au/index.php
