fj1100 wiring
Started by cjv90, December 09, 2011, 10:25:01 PM
cjv90
So i removed my fron fairing and mounted some dominator twin headlights. If youve had your front fairing off you know about the mess and tangle of wiring harness there. Has anyone cleaned that up or hid any of those wire???if so how if not any ideas???
"Ive got an arm like a rocket,cock like a bermese python,and a mind like a scientist" - kenny powers
paint the frame black like MArsh did.... it definitely helps hide the huge stock harness..  nothing can stand out if it all blends in.  :good2:
Maybe split the harness to run down both sides of the frame and tuck it inboard? .... or heat up the soldering iron and make your own abbreviated harness and go with a nice acewell digital dashboard.
the only limitation is your imagination and depth of pocketbook!
