Carb info needed
Started by Sour1, July 17, 2011, 02:12:46 PM
Sour1
I found the float height in another post (http://www.fjowners.com/index.php?topic=4482.0 Thanks for the pic!).  I also found RPM Racing's site to order parts.  I have a couple questions, though.  One of the fuel pilot jets and pilot screws need replaced because they needed extracted.  The pilot jet listed at RPM does not look like it will work with my bike (1984 FJ1100).  http://www.rpmracingca.com/proddetail.asp?prod=Carb%3APilotjet
I could not find another fuel jet listed on the site and I don't need the entire rebuild kit because I have gaskets and such already.  Does RPM have just a fuel pilot jet available for a 1984 FJ1100?  Or is there another place I can get just a pilot jet?  (My pilot jet does not have all the holes on the side of the jet.  Just one hole going straight through.)
I will be ordering the carb kit http://www.rpmracingca.com/proddetail.asp?prod=carbkit&cat=24 and wanted to order the fuel pilot jet and pilot screw kit http://www.rpmracingca.com/proddetail.asp?prod=Carb%3APilotScrew&cat=24 at the same time if RPM has the fuel pilot jet I need.
Thanks.
1980 XJ650
Those are the proper fuel pilot jets. The replacements have the holes on the sides for two reasons; to help with cleaning of the jet and secondly to give the debris somewhere to go when in the carb instead of always being pulled into the pilot jet.
You will just need to determine what jets you already have.
