how to reinforce the assembly rod headlight adjuster?
Started by delarbreavous, July 15, 2011, 10:02:53 AM
delarbreavous
Simple,
Just use two layers of flexable heat shrink tubing. It does the job!
Alain
Fluctuat nec mergitur
markmartin
You mean the assembly rod headlight adjuster that rattles all the time??
Great Idea Alain.  The next time I have my fairing off, I will do that.  I've strapped it off with a piece of plastic wire tie to stop it from buzzing but the heat shrink seems like a better fix.
Flying Scotsman
 :biggrin:
I have been wondering what the buzzing sound was on the FJ1200 I think I just figured it out thanks.
:biggrin:
1990 FJ1200
1999 GP1200 (165 + hp)
Flyover Country Joe
Alain,
Looks like a great solution, however its a little late for mine. I took the fairing off a few weeks ago to repair the cracks and busted tabs. I found the adjuster rod u-joint had worn one of the ears off of the yoke. :ireful: I'll remember that tip for when I replace it!
