carb troubles
Started by wills89fj1200, March 09, 2011, 03:40:52 PM
bike starts up fine but gas is steady running out the bottom, why?
float level
3 (50%)
hooked up wrong hose somewhere
0 (0%)
none of the above
3 (50%)
Total Members Voted: 5
wills89fj1200
Just got bike back together after installing new jets.  Bike fired right up and idled right under 1000 rpm.  Then it started to fall and it sounded like it was flooded.  Then noticed gas running right out the bottom onto the pipes.  What could be wrong?
FYI, We have a great Files section, here's one discussion that pertains to you: http://www.fjowners.com/index.php?topic=46.0
If you didn't mess around r/r the floats, I don't think you changed the float levels.
Short answer: I think the float needle is sticking open from debris and flooding the bowl, or the O ring on the float needle seat is knackered.
Before you take the carbs off, try tapping on the float bowl to see if you can dislodge the debris (if any) get the float needle seated.
IMHO Worn Float needle seat O rings, or junk between the float needle and needle seat, are the most common causes of overflowing carbs....
HTH  Pat
