so just cleaned all the carbs and mounted them on....
Started by travisreisdorf, March 09, 2011, 10:49:44 AM
travisreisdorf
just gave all the carbs an acid bath and mounted them on the bike, but wait... i dont know what to do after that haha...i did connect all wire cables from throttle and choke, something tells me theirs much more then just that, vacuum adjustments? sry this is my first motorcycle I have worked on, im used to 49cc mopeds :dash2:. pleas give me some pics, or give me directions on where all the carb lines go and how to get this beast going again!
The vents and drains and such can be left open if you're just testing, though a stuck float will pour gas all over the back side of the motor.
Plug the fuel in, throttle cables, choke cables, and things should function.
