86 fj banjo bolt size
Started by big r, January 29, 2011, 05:32:57 PM
big r
I need to know what size the banjo bolts are on the clutch,front and rear brake master cyl. are and the length of the hoses to convert to the two line system on the front . Also the length of the clutch and rear brake hose. I saw it on here somewhere butnow I can't find it. Thanks for your help. big r
TheRadBaron
Well, I can tell you that all the banjos on my '84 are 10mm x 1.25.
The desire for safety stands against every great and noble enterprise.  -Tacitus
carsick
Thanks Andy,
I was using the search for that post also because I knew I had made it, no luck...? Big R, sorry for the delay in responding, I just measured my spare banjos and they are 10x1.25. This fits both ends of all the hoses on my bike (91), only difference is the longer one (still 10x1.25) for the two lines off the master.  I just found my notes on the lengths, fittings, and degrees of rotation for all the lines, but my rear brake is underslung so no help there. If the post Andy found doesn't answer it all, ask some more!
Doug
big r
Hey thanks guys. Another dumb question can I switch to the two line system with out removing the antidive on the front. Iam fairly new at playing with brake systems.
Quote from: big r on February 06, 2011, 12:32:53 PM
you sure can!
