Wiring trouble
Started by fjman, November 13, 2010, 11:47:28 PM
fjman
How should the connections go on this part of the engine?
THE F*CKING DOG chewed the connections! :ireful:
A sample picture would really help. :good2:
Thank you
fjman
any help would be highly appreciated  :good2:
fjman
I think it should look something like this.
I dont know where the wires go to  :morning1:
And how the original connections look like
Travis398
looks like you have your oil and neutral sensors there, should be run through that bracket at the back of the motor (below the sprocket and above the shift shaft).
It looks a little bent so you may want to remove it and bend it back into shape.
they will plug into the bikes wiring harness.
