Starting problem
Started by Timmus, November 06, 2010, 06:56:31 PM
Timmus
Hi All,
I just became an owner of a FJ1100, I bought it when it was not running (Challenge for me)
Everything was loose and i had to mount all things together.
but after i adjusted the cable tree it worked a bit ( started without Air filter and exhausts )
Didn't run good (of course)
But because i already thought it wasn't running OK without the airfilter, I cleaned the carbs and hooked on the airfilter and also made some home made exhausts(most of this was broken)
It ran not OK but it stayed on for a while.
After i knew the engine was OK I started to bleed the clutch , it needed a lot of DOT 4 but after some time no air bubbles I tried to use it(no success)
After i did this and messed around with the backtire in the 1st gear it didn't run free
The engine wont turn when i try to start(or it will turn very heavy)
Now the only thing i could here was the clicking of the start relays.
Could it be that i  damaged something?
The starter engine runs OK and the dynamo is also not stuck..............
Did I maybe broke the oil pump? because I tr yd to turn wheel both sides with force................
Note:
Also something :crazy: stupid of me; I assumed there was no oil in the engine, but I disconnected the motor block from the frame now, and when i drained the oil, 6 Liters came out of it.
Sorry for my bad English i am Dutch.
If any one has an idea please let me know, i would love to ride this machine......
BTW it's an 84 model, And probably has already stood still for some time.
las1200
Hi Timmus,
wellcome to this great forum. Shurely you will get lots of help from the pros here!
Not me thow :nea: ...not experienced enouph.
hope you can fix the bike and enjoy a great ride!
Timmus
Thank you Las 1200,
Lets hope I (we) can get this fixed before next summer,
Hope someone can help me out.
