Fork Oil Weight
Started by Varget22, July 23, 2010, 07:03:51 PM
Varget22
Just wondering what weight everybody is using? I need to replace my fork seals and I'm wondering if I should go with the stock 10w or maybe stiffen it up a bit with 15w. I did them six years ago and even shimmed the bushings. Now its time to do them again.
Chris R
Sierra Vista Az
86 FJ1200
01KLR650
86 TR200(Fatcat)
if the front end is sagging/diving excessively then you want to go with heavier springs (rated for your weight) and same weight oil
thicker oil will give the stock forks a harsh ride as it cannot flow thru the damper rod holes as fast as thnner oil.
