Transpo regulator but still high voltage
Started by Waiex191, April 02, 2026, 10:00:34 PM
Waiex191
Hey guys,
Just finished connecting my adjustable VR as per the directions here. Unfortunately I'm still getting over 15 volts, even with the pot adjusted to the stop. I tried adjusting it the other way and saw over 16V. Any ideas?
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex191,
Okay, this is not likely, but you should try another Voltmeter and see if the reading is the same. If you get two different results with two different meters, you will need a third meter to say which one is wrong.
As always, check that wiring connections are clean and secure, especially the grounds.
Discharge the battery until it shows a lower Voltage, then connect the battery and check the charging Voltage.
You may have an odd battery problem. Auto parts stores can load-test the battery for you, usually for free. HTH.
Waiex191
Red,
It's a new battery. I put it on the trickle charger a week ago, and pulled it off the next day. Rode the bike a little. It showed about 12.8 when I first turned the key on. After starting and running at 3000 RPM or so, it showed 15.5 until I turned it down to the stop. Then it was 15ish. I've got a few meters and can check.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
mike g
there was a thread on here about this, but to summarise the voltage sensing wire takes its reading via the ignition switch, which given the age drops the actual battery voltage by at least half a volt or more depending how worn the contacts are. trick is to connect the battery direct via a relay switched by the old sensor wire so the generator gets actual battery voltage. I did it a few years ago and now seems to charge ok. used to eat gel batteries or dry out wet ones every few years.
Waiex191
Thanks Mike, I searched for that on the forum and have a couple more things to look at.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
81Delorean
I had a similar experience when I did the VR mod to my bike last year. It worked good for about a week and then started overcharging again. Turned out to be a bad VR. I swapped it with another one and haven't had an issue yet with it since.
1996 Aprilia RS250
1989 Yamaha FJ1200
1988 Kawasaki ZX10
1964 Honda S90
Waiex191
Quote from: 81Delorean on Yesterday at 06:48:30 AMI had a similar experience when I did the VR mod to my bike last year. It worked good for about a week and then started overcharging again. Turned out to be a bad VR. I swapped it with another one and haven't had an issue yet with it since.
Thanks!  I do have another on the way.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Waiex191
Does anyone have a writeup on removing and rebuilding the ignition switch?
Bryan
1981 Suzuki GN400
Poplar Grove, IL
