1984 fuel meter
Started by Warp84, February 28, 2026, 10:46:53 AM
Warp84
I'm just a touch South of Erie PA, looking for the fuel meter that goes inside the tank on my 84 Fj1100. OEM part code is 36Y-85752-03-00
Even with the tank filled to the brim with Ethanol free fuel, the needle never gets above half on the gauge. Hopefully there's a way to fix the meter. But having a spare never hurts either.
1984 Fj1100
Warp84,
Fuel meter issues can be caused by dirty, flaky grounds. You want shiny metal secured to shiny metal, at all grounding points. Dull metal is corroded metal. You might even consider running a dedicated ground wire to the sender unit, and another to the (several) ground connections near the fuel gauge on the instrument panel. This wire would aid, but not replace the stock OEM wiring.
That aside, see if you can snake a wire down into the tank, and physically lift the sender's float gently higher. A borescope is a good tool to use, while doing this. You can get an illuminated borescope that plugs into any phone or laptop from sellers like Amazon, for cheap. Tape the end of the borescope to a bendable wire to guide the end inside the tank.
You will be amazed at all the stuff you will find inside your walls and car doors.  :biggrin:
HTH.
Warp84
Quote from: red on February 28, 2026, 01:10:12 PMWarp84,
HTH.
I'll do a double check of the grounds, like you suggest. We do have a borescope on hand actually. A reasonably nice one. I'll make a point of shoving that into the tank and seeing what mysteries await.
1984 Fj1100
Before you start....Get a new gasket from RPM, if you have it on hand, you won't need it...but if you don't...you will.
Drain your tank. Remove the tank
Unplug and Remove the float assembly out of the tank.
Plug in the float assembly back into your wiring harness.
Turn the key on.
Now, as you *slowly*carefully* move the arm on the float...your gas gauge needle should rise and fall. Check for full sweep of the gas gauge needle. Full to empty.
Perhaps you have a leaking float that does not fully allow the float to rise up to the top fuel level? The weight of fuel in the float is keeping it down. If so, drain and seal the float.
To calibrate the float, bend the arm as needed.
Fill your tank with 2.5 gallons of fuel, approx. 1/2 tank.
Check where your gauge needle points...should be 1/2 tank.
If it's over the 1/2 mark, it reads too high...your float sits too high...drain your tank, remove the float and bend the float arm up...it will lower the needle.
Vice versa
If the gas gauge needle reads too low, bend the float arm down.
Remember how the float assembly is installed, bottom of the tank, so bend the arm the right way....dont ask me how I know this....
Take some lacquer thinner/ carb cleaner and clean the varnish off the rheostat switch.
Pat
Motofun
The other thing you can do is reset the tripometer every fill up...... :yahoo:
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Sparky84
Mine bounces around wildly after about 1/4 down after filling, wish I could stop it.
But I use the trip meter as the gauge.
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
86FJNJ
Quote from: Motofun on March 01, 2026, 06:03:28 AMThe other thing you can do is reset the tripometer every fill up...... :yahoo:
This is what I do, I just fill up every 100 miles and usually at that time I still have probably a gallon left in the tank
Warp84
Quote from: Pat Conlon on February 28, 2026, 05:24:40 PMBefore you start....Get a new gasket from RPM, if you have it on hand, you won't need it...but if you don't...you will.
Turn the key on.
Vice versa
Pat
Pat. Did as you instructed. Removed the meter from the tank (After getting a new gasket from RPM). Plugged it into the bike and checked the extents. Needle sweeps through the entire range as it should. However, if I have it at the bottom extent, and slowly raise it to halfway, it only moves to 25% up the cluster gauge. If I start at the top extent and move it down to half, then the needle correctly falls to the half position. No signs of varnish on the meter either. Any additional checks to run through, besides frame grounds?
1984 Fj1100
Sorry for the late reply...
Good....It sounds like you have a full sweep gauge and sending unit.
Don't try and calibrate based on the position of the sweep. The tank is an odd shape.
Calibrate based only on the amount of liquid you have in the tank.
