USD fork conversion advice
Started by FJ-Heretic, October 01, 2017, 12:13:07 AM
MarioR
Quote from: Pat Conlon on September 24, 2025, 03:24:17 PMHappy to help Mario
FYI if you go with FZR1000 front end...the stock FZR springs (.77kg/mm) are too light for our heavier FJ's.
 As we know, the springs control the suspension but the valves control the springs so with the heavier springs you should change the valves (unless you like boing boing boing pogo stick fork action)
After 2 variations, here's my final spec:
Oil level: 110mm
Sag: 35mm
Spring: 34.7 x 340 .95kg/mm (you could go with heavier 1.0kg/mm springs)
Race Tech Compression valve: FMGV S2045
Compression bleed #55 drill (.052in.)
Compression stack C38
Rebound stack R20
Rebound needle base setting 1 turn out
Oil 125/150 Golden Spectro cartridge oil
This should save you some work.
Pat
Pat, you are the man!
Will need to organize for you nice case of Moosehead Canadian LAGER :drinks:
It does not matter how slowly I go as long as I do not stop.
Thanks Mario, I'll pass on the beer but if we ever meet, a cuppa joe will work.
Let us know how your mods turn out.
Pat
MarioR
Quote from: Pat Conlon on September 24, 2025, 05:22:04 PMThanks Mario, I'll pass on the beer but if we ever meet, a cuppa joe will work.
Pat
You got it Pat. :morning1:
Thank you
