Valve Adjustment
Started by UJM, June 12, 2010, 04:06:01 PM
UJM
Gotta love old UJM's, simple and fun to work on.
Tank removed -
Specialited fastener containment recepticals (egg carton) and other stuff on the car.
Valve cover off
Special tool in place, holding bucket down
Had a nice selection of shims on hand
Also replaced the plugs, fuel filter, synch'ed the carbs.
Oh, 5 valves needed adjustment (all intake), and only one carb needed a minor bump.
The plan is to order up a new valve cover gasket, retaining bolt seals and a set of really awesome feeler gauges from Mikes XS then do them all to as perfect as I can get them.
Mikes XS Tool Section
Now they are "shop tuned" all within spec.
Time to ride
Ride for one - Ride for all
ccsct203
At least you have shim on top of bucket
I have shim under bucket with my Megacycle cams, ape springs and Titanium retainers...aghhhh :negative: :wacko1:
