Reverting back to fuel pump
Started by budgie7622, August 25, 2022, 07:27:23 AM
budgie7622
Hi all i was hoping for some help i have a basket case 88 fj1200 that i bought for pennys was running although quite rough i have sent the carbs out to be cleaned but i want to revert the fueling back to standard as someone had converted it to a gravity feed tank. Ihave already bought a pump petcock fuelfilter and most of the fuel lines but was wondering what size fuel line do i need going from the pump to petcock as you can no longer get it new aslo what size clips for it
1987 fj1200
melloncollie
The fuel pump models have a smaller needle and seat, you will need to replace those with the correct sets for the fuel pump model.  The Yamaha part number listed is 3CF-14107-15-00 but you should be able to find them cheaper elsewhere such as http://www.rpmracingca.com/proddetail.asp?prod=3CF-14107-15
I recently added a fuel pump to my 89 and I used 5/16 (~8mm) fuel line because its what I had laying around and it seems to work just fine.
Out of curiosity, what fuel pump did you go with?
89 FJ1200
Mikuni RS36, Hindle 4-1, Blue Dots
budgie7622
Thanks for the reply melloncollie i have bought a used fj1200 pump from ebay only because it came with the mounting bracket what size clamps do i need for 5/16
1987 fj1200
5/16?
The bike is metric. Gravity fuel lines are 10mm and pumped (I think) is 6mm. That is internal diameter. The line(s) may have a different wall thickness.  So pick a clamp that will compress the line you have.
Waiex191
Bryan
1981 Suzuki GN400
Poplar Grove, IL
1/4 inch X 25.4 = 6.35mm. Seems legit...
budgie7622
I had not realised the needle and seat would be different thank's for that in advance
1987 fj1200
Don't forget, RPM is the only place you can still get the genuine Yamaha fuel pump.
Once these are gone, there are no more...
http://rpmracingca.com/proddetail.asp?prod=YamFPump
