Melted red connector plug alternator repair
Started by Old Rider, September 19, 2021, 05:25:50 AM
Old Rider
Since i have gotten addicted to make silly writeups  i just have to terrorize you with another one  :yes:  so here is my mistakes and repair of the melted red alternator connector.
Quote from: Old Rider on September 19, 2021, 05:25:50 AM
Keep them coming, we enjoy them!
After comments are made on these informative posts, and the dialog settles down,  I'm saving these over into the File section for easy future reference.
Moral of this story: Use the correct amp rated connector. Check.
However, you gotta ask, why is this connector melting to begin with?
Old Rider
Quote from: Pat Conlon on September 19, 2021, 09:44:59 AM
OK then i may have another coming up =)
Saving them to the file section is okay with me
I'm far from a  expert but have done some investigation lately and found that electrical fretting corrosion and vibrations can heat up connectors
Dielectric grease is made to deal with that problems.Found this video
: https://www.youtube.com/watch?v=3Uck9IUIYBQ
and this : https://www.youtube.com/watch?v=6NPMbknRyNE
Also found that the charge from alternator rectifier can get too high because of a corroded contact elsewhere in the wiring like in this video:
https://www.youtube.com/watch?v=sOvBV1z7cZ0
And i forgot to mention that i replaced the connectors one month ago .They still looks good and I'm hoping they will stay good will check them regularly and
post a comment if they start to show signs of heating
Also forgot to send out one of Chuck Norris WARNING again And that is Disconnect the battery before starting this work
