Miss at high RPM/power
Started by Waiex191, November 29, 2020, 02:49:45 PM
T Legg
It's possible but I doubt it. Self healing problems usually return. I posted that I had a similar problem and suspected my kill switch was causing it because I could snap it on and off and the problem  would go away temporarily. I have since taken the switch apart and cleaned and polished the contacts and the problem has not returned.
T Legg
Waiex191
I think I will still go and take the switch apart like you mentioned.  I'm also thinking of taking off my ignition cylinder and going over that.  I can't get it into the locked position so I assume it needs some disassembly and lubrication.
We had to clean the ignition contacts on my kid's 84 Magna.  The bike kept dying on him.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
