Mods/Service/repairs done this year on my FJ1200 3cv
Started by TomJK, December 11, 2018, 04:54:51 AM
TomJK
1. 5,5 R62 rear rim, used, kit for it bought in Germany.
2. 3,5 F42 front rim, used, no kit/work needed on the 3cv type.
3. progressive front springs and new oil.
4. WP rearshock (used).
5. steeringheadbearings renewed.
6. all wheelbearings renewed.
7. checked linkage and regreased the bearings, all were good.
8. replaced all brake/clutch lines with steelbraided ones.
9. replaced all parts in brake/clutch pumps, slave and master.
10. K&N airfilter
11. Spin on oil filter kit with hiflo oilfilter.
12. Dyno jet kit stage 1
13. cleaned and replaced all jets in carbs and synchronized them with (old) Morgan Carb tune.
14. New EBC front discs wit HH pads.
15. Iiridium sparkplugs.
16. Valveclearance checked, all exhaust ones too tight!
17. Used JAMA 4 into 2 headers, without collector, SS.
18. New Delkevic 35 inch exhaustcans.
19. Enlarged airgap in fuelcap.
20. New fuellines and filter.
21. Enlarged airintake
22. Honda mirrors, old ones heavy and worn out.
23. LED indicatorlights on back, LED H4 bulb front.
24. Relays for the coils and headlights.
25. Homemade LiFePo 4 battery.
26. Bigger oilcooler.
27. Touch up black Motorparts.
28. Clutch pin extended.
29. Scottoiler.
30. LED blue dash lights.
31. Headlight protection cover.
32. Tank cleaned and sealed.
33. All rubber seals in carbs replaced.
34. New chain and sprockets, 18/40
35. Fuel pump revision and diode soldered in to stop burning in of the points.
36. Used starter motor of XJR, for better starts
Past bikes : BMWR90-S,BMW R100CS, Ducati 900SD, Kawasaki GPZ600,Yamaha FJ1200,Kawasaki ZZR 1100 (4x),Kawasaki ZZR1200, Honda CBR1100XXX,Yamaha Thunderace, Kawasaki ZX10R (3X),
Aprillia Falco,Honda CBR600F4I, bikes today : Kawasaki ZX10R (C1, the best!),Yamaha FJ1200, soon to come Kawasaki Z900.....
TomJK
And another one..
35. Fuelpump revision and diode soldered
TomJK
I am getting old, forgot this one..
36. Used startermotor of XJR, for better starts
Uh
Tom, hope you don't mind, I modified your first post to include items 34,35,36.....Whew, that's quite a list, good for you!
I am interested in your diode mod on the fuel pump. Where did this come from? Is there more info available?
Pat
TomJK
Hi
Found that one on a German site, will try to find it and send you the link, it is relatively easy to do....
Did all the mods myself, filtering through the internet, to see what makes sense and what NOT to do..took a lot of hours of searching and even more time to implement all these in the wintertime, but, while working in my livingroom, it was fun doing it...and made the FJ a better bike....
Cheers, Tom.
TomJK
