Bar End sizing
Started by ryanschoebel, December 23, 2018, 08:42:21 PM
ryanschoebel
Bit of a dumb question, but does anyone know the bolt size that is on the end of the bar ends? One of mine is cross threaded, and I need to replace the choke assy, and want to fix it with a helicoil or something similar before reinstalling.
1985 FJ1100-- Atlas (SOLD)
1984 FJ1100-- Storm
T Legg
T Legg
T Legg
                                                        Try re-tapping it before you use a heli-coil
T Legg
ryanschoebel
Thanks Travis! Why should i try to retap it?
1984 FJ1100-- Storm
T Legg
 those are long threads if they are just cross threaded at the beginning you might be able to save the original threads by carefully running you tap through them. even if the first few repaired threads are loose the inside threads would probably be enough to hold the handle ends on especially with blue locktite.
T Legg
ryanschoebel
Good to know, thanks for the clarification! I think they are pretty messed up, but its worth a shot!
1984 FJ1100-- Storm
