Turn Signal Connection
Started by Yamahahammer1300, March 17, 2018, 01:09:16 PM
Yamahahammer1300
I need to remove the turn signal/horn wiring to resolder the connection to the switch.  Looking at the wiring diagram, there seems to be a connector.  Does it exist, and where is it located, if so.
Chrome don't get you home
Yes, each of the front turn signals have a connector. One side is a Green connector, the other side is a brown connector. The easiest way to access them is to remove the black filler panels between the fairing and fuel tank.
Yamahahammer1300
Fred, you da man.  Thank you so much.
