Single pull throttle cable
Started by Indiana jones, November 09, 2017, 02:12:51 PM
Indiana jones
Is there a compatible single throttle cable for the Fj11?
That connection box set up does not suit my bobber build at all!!
I know what I'm doing so I'm aware of what not running a return cable means.
BMW R1150GS,XT600 Tenere,FJ1100 bobber, Ducati 999 BiP x 2
FJ1100mjk
Quote from: Indiana jones on November 09, 2017, 02:12:51 PM
If you're making a custom bike, why not a custom throttle cable for it? Shouldn't be rocket science to figure out what you need.
Custom Cables to Your Specifications
Or Make Your Own Custom Cable
Iron Balls #00002175
www.ironballs.com
Indiana jones
Cheers.
I was looking for an easy solution.
The Fj has that retainer at the twist grip, rather than a screw in type.
Making a cable isn't a problem, getting what I need, here in Ireland, is.....
Give Doc Hacker a shout at the FJ UK club. He will get you fixed up.
doc@fjclub.co.uk
