Dog bones
Started by yambutt, November 06, 2017, 05:28:38 PM
yambutt
My new dog bones i had made up, they a little shorter than stock so to raise the rear, and much cheaper than soupy's and more accurate as they are the exact same length
Chromed as well? Look great, precision work. On my '93 I shortened them from 12.5cm eye to eye down to 11.5cm, raised the back nicely
roverfj1200
1988 FJ1200
Richard.
yambutt
There not chrome, their 304 stainless steel, I chose 304 since it has more strength than 316 and is less brittle, these are just polished is all, also they were drilled and cut by water jetting so no chips on them at all :
Quote from: yambutt on November 06, 2017, 05:28:38 PM
Soupy links are specifically for those who want to adjust their ride height.
Different strokes for different folks.  I've done what  you did, and I've run fully adjustable turnbuckle links.  Just depends on the application.  I'll say that I'm using turnbuckle types on my current ride.
yambutt
This set is 118mm center eye to eye but having another set made 114mm and 1/8 inch fatter all the way around from 304L stainless steel that is from here in america, machinist does them for me for 20 bucks for the set then i just polish them out and they are cut from waterjetting so its very inexpensive to have another set made
