fuel reserve switch
Started by Mattman, February 08, 2017, 04:06:23 PM
ANd again.....this time where it can be seen..... :yes:
I asked about the ignition module because with my '91 I am using a Dyna 2000 system which eliminates the OEM module. The way  mine is wired I have the same symptoms as you are describing..... it will only pump fuel with the fuel reserve switch in the RES position.
I have never bothered to track down the reason for this.
yambutt
It's your sending unit, it's not sending power to the relay that ultimately sends power to the fuel pump..
Mattman
Cool, Now I just wonder how to check the sending unit with an ohmmeter possibly? I wonder who sells new ones?
past motorcycles, 26, too many to list!
Mattman
I hearing people say the sending unit is bad but the fuel gauge still works. ??
oldktmdude
Quote from: Mattman on February 10, 2017, 03:48:20 PM
The fuel gauge sender is a totally separate unit to the low fuel warning light. (reserve function works in conjunction with the warning light) Although these two units are mounted on the same framework, they operate independently.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Mattman
I was looking under the fairing and found a broken wire, green with a magenta stripe. So I pulled the fairing and found the wire broken from the fuel pump control unit assy. See attached pictures . So i hope that is the problem. In the mean time I scratched the meter cover pulling off the fairing. ugh anyone got one for sale or do you know where I can find one? lol this project keeps getting bigger and bigger.
Quote from: Harvy on February 10, 2017, 02:14:31 AM
Mattman
Quote from: Mattman on February 11, 2017, 01:08:40 AM
Just to follow up....Today I attached the green wire with the magenta stripe back into the connector put the fairing back on and took her for a ride and walla! the reserve switch is operable in the run position ! ya
yambutt
Hopefully that will fix the problem, let us know
Mattman
Quote from: yambutt on February 13, 2017, 07:55:07 PM
It did fix the problem!!! Yahoo
Quote from: Mattman on February 13, 2017, 08:08:21 PM
It did fix the problem!!! Yahoo Kookaloo!!!
Fixed it for you....
Mattman
Quote from: FJmonkey on February 14, 2017, 01:24:31 PM
oh I didnt know, lol      Kookaloo!
Kookaloo is unique to the FJ, it even made the urban legend dictionary.
http://www.urbandictionary.com/define.php?term=kookaloo
Long live the FJ...
Mattman
Hey thats really cool, I didnt know
