Sealant on slave bolts?
Started by 4everFJ, April 12, 2016, 02:00:04 AM
4everFJ
The OE service manual says to add yamabond to two of the bolts that holds the clutch slave cylinder.
Anyone who knows the purpose of this? It is just bolts that screws into the casing...
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
Maybe to keep chain-lube gunk from seeping out through the threads?
I'm not sure if the threads go all the way through the sprocket cover?
4everFJ
Quote from: Firehawk068 on April 12, 2016, 08:48:45 AM
No, that wouldn't be the reason.
Those two bolts go into the casing. The third one (that doesn't require sealant) goes into the sprocket cover.
1978 - Yamaha SR500
Randy might be able to answer this one?
I have never put any sealer on my slave cylinder bolts, and I've never had an oil leak there?
