FJ1200 rear wheel swap
Started by Scottie1, March 02, 2019, 09:45:43 AM
Scottie1
I am half way through doing the front swap for a 92 front end and have a 92 rear wheel ABS. I want to keep the wheels the same style. Now question will is this a straight swap out as I noticed the 92 sprocket is 40 and the 86 is 41. Also obviously the 92 ABS wheel is slightly different. I don't want to go through fitting it and it doesn't fit correctly. Any input would be greatly appreciated.
1986 FJ1200
1982 XJ750 R Seca
The ABS wheels may not swap over as a bolt on.
Scottie1
That's what i was afraid of it was a spur of moment decision being the wheel was $20. I will just get one that fits. Thank you
1986 FJ1200
1982 XJ750 R Seca
