Fork oil
Started by willismcclean, February 21, 2016, 07:25:47 PM
willismcclean
Howdy people,,, I'm changing my fork seals,,, what oil do you recommend to refill with
Yamahammer1200
ATF DX3.  I'm assuming that's Dexron III in the U.S.? Is that a 10W?
Chrome don't get you home.
Yes, its Dexron3.  Approx = 15wt.
       ATF vs Oil Wt Equiv
> Chrysler ATF+3 = 10W
> Dextron 3/Mercon = 15W
> Type F = 20W
I have RaceTech Emulators and 0.95kg/mm springs in my forks.
Prior to that, I was using a mix of 10 + 15wt fork oil and that worked fine.
Its just easier and much cheaper to find ATF, and it works just as well.
Its high detergent, and is very temperature stable.
I fill to 130mm from the top with springs out and forks collapsed.  YMMV
