Hello from South Africa
Started by Sparafucile, January 22, 2010, 06:54:10 AM
Sparafucile
Greetings from a sunny South Africa 28deg C,
Im in the process of buying a FJ100, not to sure of the year, just that its red and white, needs a new seat cover and is missing the chin fairing. Ive started her up and the engine sounds sweet and since i got my first rz50 back in the 80's I have always wanted a FJ.
 :hi: Welcome to the club house Sparafucile...........you have come to the right place  :good:
waricle
Pictures!! we need pics!
Welcome too.
Welcome to the group.... i hope your deal goes thru so you may find your own KOokaloo!
:good2:
Sparafucile
Got her on Sat, started her up then she died and wouldn't start??? Took the tank off and she started no problem, turned the fuel valve to pri position, put the tank back on started again only to die a fem min later, drained the tank added new fuel then noticed that the fuel pipe could of got pinched when i put the tank back the first time, also there is an in line fuel filter. Anyway got the bike running and drove her for about 18km. When cold the bike idles around 1000rpm but when warm she sometime stays just above 2000rpm, but otherwise the gears appear to be fine and there is no nasty noises from the engine.
Welcome.
You'll find after reading some of the previous maintenance posts that most of your described problems are pretty normal.
The early bikes (without fuel pumps) were very critical of fuel hose routing, and that putting an extra filter inline could create problems too.
Normal idle is between 1050-1150 at operating temps.  You'll need choke to keep it running while cold.
It's likely that your carbs need a clean, and balance (at least), but nothing you've described should hold you back for long.
Sparafucile
Thanks for the info Arnie, Planning on doing the carbs, new fuelline etc in the next couple of days
Sparafucile
found the problem the idle screw was set in so that the bike could start without the choke???? Anyroad adjusted the setting now she purs like a content kitten when warm waiting for her to cool down to test her.
kaalkoejawel
hey sparafucile!
good to see a few SA guys here!
where are you from?
how much did you get the FJ for?
almost done!
Sparafucile
Im in Randburg, paid too much R18000.00, I say that cause I still have to register, roadworthy etc, looks like the bike has stood for a couple of years, there is rust on everything.
kaalkoejawel
Quote from: Sparafucile on February 03, 2010, 07:19:32 AM
1100 or 1200? what year model?
almost done!
Knuckles
Gr8, another Souf efrican. This looks like a really gr8 site
If U r looking for service manuals and info, I have, lots of it. Just give us a shout, I am normally in Krugersdorp, but will be in northern Malawi until the 15th of Feb.
I am also on the Thinkbike forum, same nic.
