running problems
Started by badams, July 24, 2015, 11:44:44 AM
I worked my butt off on a former member's FJ.  It would start but just didn't want to run well.  I went through the carbs several times and couldn't find anything.  I finally gave up.  A few days later he called me to say he replaced the plugs and it was running like a top!
badams
Thanks for all the input.
I broke off one of the kill switch wires putting it back together, arrrg! Another part coming off the parts bike. Completely dismantled switch and cleaned all the contacts. replaced the whole handlebar harness. no change
I did replace all the plugs with new. no change
Is he ignitor that square thing underneath the fairing? worth a try since I had to remove the fairing to replace the right handlebar harness.
I will need to get a timing light to check the timing.
Do yamaha dealers still have the ability to test IC box?
Fix the Run/stop switch wire :).
I think the FJ 1100 TCI box is located back by the battery?  It is in a potentially corrosive area for the connectors.
Timing light is handy to check timing and if nothing else to see if you have a spark signal.  Borrow one or check used tool places. I see them at yard sales occasionally.  Electronic ones are the best of the group. They are not in high demand anymore with the newer cars, lot of them sitting in tool box's.
Try Harbor Freight $19.99
http://www.harborfreight.com/xenon-timing-light-3343.html
HARBOR FREIGHT STORE
MINNEAPOLIS, MN #00137
725 45TH AVE NE
MINNEAPOLIS,MN 55421
763-571-9390
Bozo
Maybe I misread the previous replies so please don't kill me, has the cam timing been checked?. I am assuming it ran well prior to this problem.
