No power on pull away
Started by casper, August 12, 2015, 04:01:57 AM
casper
Hello guys
I've got another problem.
If I try to pull away on a uphill at a stop, and blip the throttle just before take off, my 1100 does not have any power. It seems like the carbs are flooded for a 2 to 5 seconds timespan, and only then starts to really go.  What is the problem here?
Casper Jordaan
1984 - Yahama FJ1100
1982 - Kawasaki K1 2-Stroke
2005 - Hyosung GT650S
1981 - Suzuki DR500
2011 - Jonway Laguna
2010 - Jonway Spray
1999 - Sundiro XDZ
1994 - Yamaha DT50
1980 - Kawasaki AR80
Are they stock carbs?  Have they been "improved" with a jet kit, or molested by someone who believes that bigger is always better?
Are the diaphrams in good condition?
Has the ignition pick-up plate been modified to change the timing?
That should give you a place or two to check :-)
Sounds like you're flooding on the low end....Clean your carbs, replace your float needle seat o rings, check the fuel level in the carb bowls, set your float heights, adjust your air/fuel idle screws.
