motor mount torque values 1989 FJ1200
Started by anson45, July 18, 2015, 10:53:04 AM
anson45
     I have a Haynes Manual and a Clymer. The listed motor mount values are different. Does anyone have a Yamaha Shop Manual?
Haynes, page 2-4, lists for 1984-1990: upper damper bolts = 40 ft-lbs, flange bolts = 65 ft-lbs, rear down tube-to-frame bolts = 40 ft-lbs. Clymer, page 159, lists for 1984-1990: upper front through bolt and nut= 40 ft-lbs, upper rear through bolt and nut = 40 ft-lbs, Lower rear through bolt and nut = 65 ft-lbs, and Sub-frame upper and lower bolt and nut = 20 ft-lbs. I and the po's used the Haynes values.
So my question is, what are the Yamaha values?
Thanks,
Anson
1981 XS650H
1983 XVZ1200 (original owner)
ct7088
Front and Rear Upper and Rear Lower Engine Mount 40 ft/lbs (M10 X 1.25)
Rear Lower Engine Mount 65 ft/lbs (M12 X 1.25)
Front Frame to Rear Frame 40 ft/lbs (M10 X 1.25)
I hope that the picture of the page shows.
Chris
Chris
ct7088
Chris
ct7088
Chris
anson45
1981 XS650H
Burns
thank you both for making this great thread.
