indicator relay?
Started by bigjiz, June 23, 2015, 11:44:56 PM
bigjiz
Hey all, Just wondering does anyone know where the indicator relay is located on a 1985 fj1100?
Timbo-1
Simple question, but hey not sure, think it's right hand side under fairing behind head light??
Attatched to a rubber clip arrangement? :unknown:
Hope this helps but sure someone will know for certain,
Cheers Timbo...
Life's been good to me so far....
I don't own an early FJ but my manual indicates that the turn signal relay is on the left side up front mounted to the frame with a rubber bracket.  Looking down it is slightly ahead of the steering stem.
You might be able to "peak" at it by removing the left side dash panel ?  Pretty tight in that area. you might have to remove the upper dash. That's about all I can tell you at this point.
