carb cleaning
Started by Cash Dereszynski, March 28, 2015, 10:39:57 PM
Cash Dereszynski
Simple question ,how do you get the emulsion tube out? Tap tap or threaded screw in jet threads? Does it come out the top or bottom?
Thanks in advance,
Cash
Fuck it,let's ride.
Quote from: Cash Dereszynski on March 28, 2015, 10:39:57 PM
Thanks in advance,
Cash
Remove the jet and it should press out from the bottom to the top.  Comes out toward the top. You can remove the jet and washer, then thread in the jet (minus the washer) and gently push/tap on the jet when loose remove the jet and remove the tube.
