Is my handlebar bent from an accident?
Started by chiz, March 19, 2015, 02:12:01 PM
chiz
Hello all
I removed the right handlebar to install some cables and noticed the bar is bent in two planes..Slightly down and slightly back about 11/4 inches from where the tube attaches to the casting... the bar weight is in perfect condition.... Don't want to remove the other bar to check if that one is the same.
Thanks Chiz
Might just be from a tip over. If only slightly bent it could be bent back to near as straight with no issues.
You will have to compare to the other one to be sure . Remove and put both on a tube and see if they match angles .
Or leave it alone if you don't mind a little difference and it dosen't bother your shoulder or hand when you ride.
I have mine angled different because of an accident that resulted in one arm longer than the other and had to stagger the handle bar to fit.
Steve_in_Florida
Quote from: Mark Olson on March 20, 2015, 02:06:37 PM
...because of an accident that resulted in one arm longer than the other...
Man, botched surgery is a BITCH!
`90 FJ-1200
`92 FJ-1200
IBA # 54823
Quote from: Steve_in_Florida on March 21, 2015, 08:49:47 AM
[/quote
yeah, really messed up my golf swing.
Quote from: Mark Olson on March 21, 2015, 02:33:12 PM
Picturing you swinging a golf club reminds me of Bill Murry in Caddy Shack....  :rofl2:
Quote from: FJmonkey on March 21, 2015, 07:52:14 PM
funny .  :rofl2:
