Tools: New Bench Buffer
Started by Pat Conlon, March 15, 2015, 01:45:40 PM
Well folks, after over 50 years of use my dad's 3/4hp buffer motor finally died...kind of sad actually, oh well...
I just ordered a new 1hp 2 speed model with 10" buffing wheels:
Monkey Mark, plan bringing those ss header tubes out in April. I've got a stick of black cutting compound that should work on removing those machine lines on the stainless...
roverfj1200
Maybe you could do some of my parts...... :flag_of_truce:
1988 FJ1200
Richard.
fj johnnie
 I suspect if you post your address a ton of parts will "show up", mine included.
TexasDave
Quote from: fj johnnie on March 15, 2015, 04:22:39 PM
Please bring it to the rally. I promise I will bring my generator!   :biggrin:  Dave
Charlie-brm
What's the purpose of the pointy bit on the right side shaft? That's new to me.
1979 XS750SF - 2005 to 2012
Thanks Leon!  :drinks:
My dad's smiling about now....
Silly, I know...it was just a tool...
I guess I am taking the dark path of polish and shine. What's next? The Red Power Ranger on a Stormy Blue....
The earth has just shifted on it's axis....
yamaha fj rider
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
Quote from: Charlie-brm on March 15, 2015, 08:30:20 PM
It allows for different wheels to be changed quickly. They are LH & RH threaded (for the L & R sides of the bench grinder)
The centres of the buffing wheels have a nylon flange fixed onto the outer surface on both sides that crudely threads onto the tapered shaft (in the opposite direction to the load) They are there for just that purpose.
It enables quick changes of wheels, a few seconds, spin one off, spine one on. So, you have one bench grinder and a number of wheels. The centre of the wheel has no thread, it sort of self taps on and is not under any great load so the the wheels can be changed endlessly.
I have a number of wheels and polishes but really only use one wheel, one polish for pretty much everything.
CanDman
Shine on brother !!!! Crazy Diamond.....  :crazy:   :blum1:. Pat....looks like I will be seeing you in June finally.....looking forward to it ...  :good:
Kev
krusty
The pointy bit can be used for different fabric wheels. Mine has a wire wheel on the left and just the pointy shaft on the right. I can quickly swap between different cloth wheels in a few seconds. There's really no need for the wheels to be fixed to the shaft.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
