fj compress in cylinders
Started by JOMPPA10, February 08, 2015, 06:58:07 PM
JOMPPA10
Iam only only asking what is normal in cylinders in that engine, by meaning is my engine in good,medium,bad.160 000 km  back,workhorse i suppose
If you are asking about the compression.
The compression spec's for the FJ 1100 are at sea level, throttle plates open.
Standard  142 PSI /  980kPa    The FJ 1200 lists the standard at 149 PSI
Min.         128 PSI / 882kPa
Max         171 PSI / 1176.8kpa
