4000-5000 RPM glitch
Started by JPaganel, August 25, 2014, 09:21:33 PM
Just throwing something out there..... Being as this problem is on an 86' and gravity fed, could there be a pinched/obstructed fuel line? At lower rpm's the engine has sufficient fuel and once the RPM's get higher and the engine is demanding more fuel, there is starvation....
1990 FJ1300 (1297cc) Casper
JPaganel
That's a thought. I'll check for hose routing.
It occurred to me that maybe I should pull out the choke when it does this, to see if there is any effect. And when I decided to try that it didn't do it the whole way home.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
