OEM Clutch Rebuilt kit, contents question: viscous fluid?
Started by JoBrCo, August 22, 2014, 06:30:50 PM
JoBrCo
I was wondering of anyone knew what the viscous fluid is for, that comes with the OEM clutch rebuild kit. It's a bit more viscous than Dot 3 or 4 hydraulic fluid.  I'm not sure if it's some kind of oil for lubing the lever, or old thick hydraulic fluid, to pre wet the seals/cylinder to reduce both, friction, and the potential for damaging the seals, during assembly.  My nose seems to be drawing a blank, olfactory nerves declining too, I guess.  It's inconsistent with the other two 'brake' master cylinder kits, in that it's been excluded from them??  Why is the clutch different? Special mystery oil so non-clairvoyant people ask stupid questions on a forum?  I didn't notice it mentioned in the manual either; an after thought?
Anyone know what it's for, that cares to enlighten the clueless?
TIA
FJ Forever!   :drinks:
JoBrCo
1985 FJ1100NC
"To 'truly' see the man in the mirror, the only way for the image to be clear, as the man then 'truly' grows" --JoBrCo--
'I only know that I know nothing' --Socrates--
Quote from: JoBrCo on August 22, 2014, 06:30:50 PM
TIA
JoBrCo
Most rebuild kits come with a sachet of seal friendly (non petroleum based) assembly lube.
JoBrCo
Thanks Noel.  I thought it might serve that purpose, but was afraid to take a chance at mixing incompatible fluids.  They should put a brief set of directions in the kits since the GYSM has no mention of the kits contents.
Really appreciate it!
JoBrCo
1985 FJ1100NC
