Gasoline in the Oil Pan
Started by theLeopard, May 12, 2014, 11:28:03 PM
Ok late to this party ,,
pull the plugs and turn the engine over with the starter.  does fuel spray out?  like a big wet sneeze.  do your carbs over.
did you ever jump start the engine with a car battery ? cause it would not turn over.  if so you bent your rods due to fluid lock and now it runs like crap.
do a compression check on each cylinder.  post the results.
If you all have already mentioned all this great.  I am now an echo.
