Honda Clutch master cylinder swap on 84FJ1100
Started by charleygofast, May 14, 2014, 06:32:46 PM
charleygofast
Hi, does anyone know if a 84 Goldwing clutch master cylinder will work on my 84FJ?  I found one in excellent shape that I may buy if its compatible. The other option is the new Chinese VFR800 set Fred talked about using in a post last June. Any advice on  either of these options?
Thanks! Charley
1984 Yamaha FJ 1100
1981 Yamaha XS 650
1985 Suzuki SP 600F
1979 Yamaha XS 1100        2015 Kawasaki KLR 650
oldktmdude
   Charley, can't tell you anything about the Goldwing m/c but the VFR800 m/c is a good mod. I fitted mine a few years ago and I can't fault it in any way.
It's a basic bolt on change-over, with no other mods required. Having a 14mm bore has made clutch lever pull very easy, even with the doubled-up diaphragm springs. The adjustable lever is a worthwhile bonus, spare parts are cheap and easily obtained and it's also is a good looking unit.  Regards, Pete. :good2:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
fintip
No way to know without trying, never heard of someone doing that swap. There's probably *some* way to get it to work, they're pretty universal parts, it just might take some trouble getting it to fit... Look up bore size.
Safer to go with known mods, of course.
Can you give a link to where Fred talks about chinese VFR800 M/C's? I haven't seen that post, I might add it to the wiki.
fjowners.wikidot.com/
-ZAMM
IBA:54952
oldktmdude
Quote from: oldktmdude on May 14, 2014, 10:26:45 PM
I must say that the above post of mine refers to a GENUINE HONDA VFR clutch m/c and not the Chinese knock-offs. I'm not sure of the reliability and suitability of these copies but they are cheap enough. Having said that, genuine VFR m/c's are fairly cheap on ebay and that would be my preferred option. Pete.
2009 TDM 900
2004 GasGas Ec300
charleygofast
Pete, are you using the same m/c Fred was talking about last june? Those appear to be decent units and the price is awesome for both brake and clutch. Im still not sure about the Goldwing unit, but am going to check it out this weekend. If it doesnt work out I will order the VFR units./Thanks again! Charley.  ,quote]
1984 Yamaha FJ 1100
1981 Yamaha XS 650
1985 Suzuki SP 600F
oldktmdude
    Sorry Charley, I should have clarified that in my first post. No, I'm using a Genuine Honda unit as stated in my second post
2009 TDM 900
2004 GasGas Ec300
charleygofast
The post on the VFR800 master cylinders is un der files section and clutch files. Then find "Honda clutch master cylinder mod"by AviationFred. Scroll down to end of Freds last post and there is a E bay site attachment to click on. Looks like pretty decent stuff!        Good night.Charley              :morning2:
1984 Yamaha FJ 1100
1981 Yamaha XS 650
1985 Suzuki SP 600F
