Changed spark plugs
Started by Joe Sull, April 15, 2014, 04:00:19 PM
Quote from: Pat Conlon on April 18, 2014, 11:25:29 AM
The carb sync uses the same vacuum port as the advance, so by default the vacuum advance is disconnected.
Blip test, idle mixture screws, leaving it connected makes no difference.
I got a chance to go through the sync and mixture screw adjustment today. I think it takes some time to get good at it. I managed and felt more confident at the end.
I started off by rigging the fuel bladder. Your idea of using a small engine fuel tank was right inline with what I have at hand.
I drilled and wood screwed the tank on the dowel and slipped the little hose inside the big hose. It sealed up good. never seen a drop of fuel escape.
Looks like a potential streetfighter mod. :gamer:
I set the mixture screws at 2 turns and took off the TCI hose.
Balanced 1 to 2 and then 3 to 4 and then 3 to 2. I did some blips and fiddled around with the mix screws but it still sounded wrong.
I plugged the TCI back into the #1 port and set up my mano on 2 and 3. It ran instantly better without turning a screw.
I adj. 2 to 3 then switched and did 1 to 3 and then 3 to 4. It sounded 10 times better then.
I did the blip and it was dropping below so I turned out a whole turn to 3 and the blip hung up. I got it at 2 1/2 and the blip is good.
I need more practice but I'll get it. Thanks for all the help. Didn't drive it today, I got a back pain and I'm kinda resting it.
I will let you all know.
Sounds like you are using a home built 2 channel manometer...if so don't leave those unused vacuum ports open while your balancing the other two..... and while performing the blip test.
#1 port should go to your petcock and #2 should go to your advance.
Ya! No, I wouldn't leave any open ports. I made a couple of extra plugs, REmoving those factory plugs as little as possible.
No harm in moving the TCI over to #1 though. I wanted to do the sync the same way I did it the first time 1-2 3-4 then 2-3 but I'd have to re-route the TCI hose to make it to 3.
The engine ran different with the TCI plugged in so I re-sync'd them. It must have something to do with timing, I guess.
