89 fj1200 carbs ?
Started by 1989fj1200russ, March 01, 2014, 07:45:58 PM
1989fj1200russ
OK when I ride my 89 fj1200 some times it fills like its only running on two plugs or like its loaded up. and when its doing this its leaking gas out of the overflow tubes under carbs. the bike will do this when its cold or hot . and other times it runs fine .I cant trust it for a long ride anymore. I think its the needle and seats but I don't want to take it apart till I get some more info on it any help will be cool. Thanks Russ covina cal  :dash2:
I can't say that it is the same cause that I had. Last summer I had a similar issue. I believed it was a float or two that was sticking and staying down. I removed my carbs, then the float covers and cleaned everything well with carb cleaner. Got it all back together and have not had an issue since.
Hey Russ, yea your bike is loading up from excess fuel. Yep float needle seats need to be removed and cleaned and importantly...new o rings installed on the needle seats. You might have dirt on your needle seat or you might have a knackered o ring. Best to do both and call it a day.
I grew up in Covina. Where do you live? I used to live on the Mesa (Mesarica). Cheers  Pat
Welcome Russ, another SoCal member. I would offer to help with the carbs but I will be unavailable for the next 4 weeks. Many of us use Randy for FJ parts including carb parts and other custom bits. He is a member and legends racer/builder so he knows these engines really well. He is currently in the land down under for the Aussie FJ rally but his son is running the shop. You can find it here at www.rpmracingca.com
1989fj1200russ
Quote from: aviationfred on March 01, 2014, 08:06:03 PM
Thanks for getting back so quick fred the info will help
1989fj1200russ
Quote from: Pat Conlon on March 01, 2014, 10:05:33 PM
Ok thanks Pat for getting back so quick with the info on carbs it will help when I do the work .yep I live over by berts mega mall in Covina
1989fj1200russ
Quote from: FJmonkey on March 02, 2014, 09:26:59 AM
thanks fj monkey for the quick info it will help when I do the work
