Clutch not engaging
Started by nandog30, October 05, 2013, 10:45:50 AM
nandog30
Quote from: nandog30 on October 05, 2013, 01:10:22 PM
I'll give that a try, the po said it sat for a season but you never know. I did open the clutch cover and inspected the plates, they seemed to move freely when I took a couple of them out.
I'll probably buy a slave rebuild kit because after I opened the clutch cover and inspected everything, I tried to bleed it again and got no pressure on the clutch lever.
Did you accidently pull the clutch lever while the clutch pack was apart ? A tell tail sign of a slave leaking is paint removed under and around the slave cylinder.
While we are talking about clutch slaves, do not start your engine when your slave cylinder is off. I mean do not turn it over, do not start it, in fact remove the key..... :lol: :lol:
Quote from: nandog30 on October 05, 2013, 01:14:18 PM
Try www.rpmracingca.com. Randy has good prices, quick shipping and he stands by his products 100%.
The kit: http://www.rpmracingca.com/proddetail.asp?prod=Clutch%3AS%2FK&cat=39
Quote from: FJmonkey on October 05, 2013, 04:38:45 PM
+1  Heed the Monkey.   :yes:
nandog30
Thanks guys, I'll order the part and let you guys know what happens.
